Free Shipping on orders over £300*
*UK Mainland only
Please read
LAMINATED POSTERS
FULLY ENCAPSULATED LAMINATED POSTERS
Printed on 260gsm gloss media before lamination, this gives the product a total weight of 510gsm.
Suitable for signs, menus, etc. Much more durable than standard posters. They can be used and reused many times with a dry-wipe marker. Great for menus with changing prices and specials! The 250 micron gloss laminate makes these very handy for durable outdoor signage. Theses laminated posters are available in single-sided print only.
All paper sizes include a 3mm white border around the print. You must include this in the size of the print you are ordering.
Select the size you require from the drop down menu. Need more that one? Simply change the quantity in the cart. Unsure about size?
Click here
Please read
CRYSTAL LAMINATED POSTERS
Printed on tough, 190gsm polypropylene banner material before lamination. This gives the product a total weight of 260gsm. Crystal lamination has a satin finish.
Suitable for many uses including signage, A-boards, menus, etc. More durable than standard posters. The crystal laminate makes these posters waterproof, scratch-proof and suitable for indoor or outdoor use. It is very flexible and durable. Theses laminated posters are available in single-sided print only. If you want a more rigid product, you should purchase the standard laminated posters (above).
              The crystal laminate is applied front only but is still fully waterproof and suitable for outdoor use.
A wide range of custom sizes are available in this product, please e-mail us for a quote!
Select the size you require from the drop down menu. Unsure about size?
Click here
SIZE GUIDE
A1 is 841x594mm or up to A1+ at 36x24 inches
A2 is 594x420mm or up to A2+ at 24x18 inches
A3 is 420x297mm or up to A3+ at 18x12 inches
Click HERE for a Paper Size Chart
PLEASE READ OUR FAQ FOR MINIMUM FILES SIZE REQUIREMENTS
